VPEX.AutoConfig.CscdUnsuprtSlot
Description
VPEX auto-config detected a cascaded BPE on a BPE slot that does not support cascading. The BPE detection will be ignored and no associated VPEX configuration will be added.
Remedy
Reconnect the subtended BPE to the controlling bridge directly or to another BPE which supports cascading.
Severity
Warning
Message Text
BPE slot %slotNo% does not support cascading
Message Parameters
Name Type
slotNo uInt
